PostPosted: September 14th, 2012, 3:38 am
I decided to take the forum one step further. I'll make a few userbars and I will put them here. If you have any, please post a reply bellow.
WARNING: ONLY Xwidget-related userbars are allowed!!!
Series #1:
File comment: Series #1
Xwidget Userbars #1.rar [185.08 KiB]
Downloaded 1190 times
PostPosted: September 14th, 2012, 5:03 am
That's looks nice ! I never knew how to make those kind of thing. Is there a easy way i can make myself some banners for the widgets i mad?
Also next time double check the topic u post too, its getting confusing when people post unrelated stuff in the "Development" section. Thanks 8-)
PostPosted: September 14th, 2012, 5:15 am
Making banners for your widgets is extremly simple, if you want me to, I can make a tutorial on that. And the reason I posted this here is because there is not topic for forum and website, so... I decided to put it here... e.e I'm sorry if I confused you.
PostPosted: September 14th, 2012, 5:20 am
I would like to know how to make that animating thing's to work. thanks alot
PostPosted: September 14th, 2012, 5:55 am
I'll make a tutorial ASAP, it'll be done in a few minutes. I'll provide you the link at the resources :)
PostPosted: September 14th, 2012, 6:57 am
Final product:
Step 1: Create a document as shown in the image
Step 2: Make a new layer, name it "Background" and color it in with any color
Step 3: Right click the layer you just created and click "Blending Options..."
Step 4: Check the box next to "Gradient Overlay"
Step 4a: Make the gradient (I used the standard Xwidget colors, since I'm making an advertising banner for Xwiget)
Step 5: Open the image "54.png" in a new tab
Step 6: Click&Drag it onto your ad banner and place it in the spot indicated
Step 7: Accidentally jumped over step seven, I'm going to continue... e.e The numbering of the images xD
Step 8: Place some text onto the image
Step 9: Add some effects
Step 9a: I used these effects
Step 10: Set the title's opacity to 0% and move the small text bellow the image as indicated
Step 11: Add another layer, color it any color, set the fill to 0% and add stroke effect, inner, 1px, black
Step 11a: This is how the layer bar should look
Step 12: Go to Window > Animate and the animation bar should open (Set it to timeline view)
Step 12a: This is how it should look
Step 13: Open the properties of the layer with the logo and click the timer next to "Position"
Step 14: Move the logo with your arrow keys all the way to the left side of the banner until it goes off-bounds (Mine is almost off-bounds)
Step 15: Play with the animations on the other components. I use the position for the small text and the opacity for the title
Step 16: File > Save for Web & Devices...
Step 17: Set it as shown and click Save.
And there you have it! If you don't understand a step tell me, I'll explain it.
File comment: Images and resources
Animation Tutorial.rar [2.55 MiB]
Downloaded 1302 times
PostPosted: September 14th, 2012, 9:36 pm
Thanks man! gonna try it
PostPosted: September 20th, 2012, 6:09 pm
Thank you very much, I will try it :)
PostPosted: December 10th, 2012, 5:19 am
Scrolling Shortcut With Mouse Wheel, Can it be possible?
deviantart Profile
Facebook Profile
Users browsing this forum: No registered users and 45 guests
