 Post subject: Creating instances
PostPosted: September 5th, 2012, 8:50 pm
I want to add a new shortcut dynamically. The question is how to create a new instance of a core or new text and add it to the layer / parent / widget?? like that:
//Not working:
shortcutArr[i] = new ShortCutCore();
//Not working:
textArr[i] = new Text();
//Set core and position.
textArr[i].Core = shortcutArr[i];
textArr[i].Left = i * textArr[i].Width + 20;
textArr[i].OnClick = openShortcutOnClick;
// How to add child to parent?
layerTextContainer.AddObject(textArr[i]);
 Post subject: Re: Creating instances
PostPosted: October 9th, 2012, 8:59 am
I found a method in the auto complete that says:
class.Create(parent);
So I did
text1 = Text.Create(widget);
Then defined all the attributes a default text object has in the xul file.
It seems to work, I can print all the attributes, but it doesn't want to show up in the skin, so there may be something special you have to do, if it's even possible.
I'd really like to see this work too, would be very useful.
deviantArt profile
My Widgets:
Game Specials v1.1
Users browsing this forum: No registered users and 41 guests
