 Post subject: Save VARs
PostPosted: September 3rd, 2012, 11:14 am
Could you give any information about how SaveValue and SaveIni work?
I need to use vars like 'cookie' for settings ;)
 Post subject: Re: Save VARs
PostPosted: September 3rd, 2012, 4:37 pm
you can uses setValue to save config, etc:
setValue("myconfig1","aaa");
saveIni;
and when widget Onload, you can load values,etc:
var  a = getValue("myconfig1","defaultValue");
PostPosted: September 3rd, 2012, 9:32 pm
Thanks! :)
PostPosted: September 5th, 2012, 8:46 am
what about set and get Array?
Can I save not string value?
setValue("images",imgArray);
getValue("images","defaultValue");
cause, I don't known why is not working for me.
runtime error 'imgArray[...].param' is null or not an object
or it should be like that? :(
for (var i=0;i<array.Length;i++)
      setValue('image'+i, array[i]);
     imgArray[i] = getValue('image'+i, "defaultValue");
PostPosted: September 6th, 2012, 12:11 am
try it
function text1OnClick(Sender)
  var a=new Array(4,5);
  Setvalue("a",a)
function widgetOnLoad()
  var b = new Array(2,3);
  var c = new Array();
  c= GetValue("a",b)
PostPosted: September 6th, 2012, 3:12 am
GetValue("a",b)
Could you explain what does second param (b) on getValue and why?
PostPosted: September 6th, 2012, 4:52 am
Shezoid wrote:
GetValue("a",b)
if there is not a variable "a" in the file(for example, you have not SetValue() before), you will get b , b is a default value
you can understand it at this way
if(getvalue("a")==null) c=b;
else c=getvalue("a");
PostPosted: September 6th, 2012, 5:36 am
Understood.
I found some bug...
Try this:
  Setvalue("a",a);
  c= GetValue("a",b);
  print(c[0]);    //print:
  print(a[0]);    //print: 4
  print(c);        //print: 4,5
  print(a);        //print: 4,5
PostPosted: September 6th, 2012, 5:46 am
i'm sorry , the getvalue() function can only get string variable
you setvalue() a Array variable , but the value is saved as string
we need a string variable to help
  Setvalue("a",a);
  var s;
  s= GetValue("a",b);
  c=s.split(",");
