It is currently June 13th, 2025, 4:43 pm
Post new topic Reply to topic  [ 17 posts ]
PostPosted: January 24th, 2017, 7:04 am
Hi !
I can not recuperate the GPU temperatures as well as the fan.
I have installed aida64 and set the installation path but it does not work
thank you :) :)
// ===== Contact ===== //
https://discord.gg/9vyhv3F
// ===== My Widget ===== //
PostPosted: January 24th, 2017, 8:25 am
Try this one:
https://www.techpowerup.com/gpuz/
PostPosted: January 24th, 2017, 10:55 am
I installed the software but how to recover the information I need?
PostPosted: January 24th, 2017, 12:01 pm
As I remember (because I tried it once) the program should run on the background and then create a widget using the tags for the temp/fun. Running the widget the values will load automatically.
I don't remember though if I had used this program. But I'm sure that it worked.
PostPosted: January 24th, 2017, 12:29 pm
Yes I think this is doable but I do not really understand or I have to put the tag, and if I have to use a core .... And what tag especially (ex : % GPUTemp)
Thank you
PostPosted: January 24th, 2017, 1:44 pm
Add a text and then add a core hdd, cpu, ram etc according what you want to reproduce.
Then select the binding core from the list.
I don't know if it will work properly using rotator or roundline but using text will show the exact values
PostPosted: January 24th, 2017, 2:19 pm
For HDD, CPU and RAM is not a problem with core but
No core for GPU....Wath is the way for show GPU Temperature, Charge and fan speed ?
PostPosted: January 24th, 2017, 3:43 pm
Search each code for its binding tags and you will find the available values there.
PostPosted: January 25th, 2017, 12:59 am
it's possible, create core for GPU for easy way ?
I am a beginner with xwidget and without the Core I understand not too how recovered the value I need ... Do you have any tutorial or explanatory documents to improve my knowledge?
PostPosted: January 25th, 2017, 1:31 am
No.. You can use only the available tags. You can create advanced functions though using XWidget, but you need some serious prof java script writing.
Check this section for help and tutorials
viewforum.php?f=1
PostPosted: January 25th, 2017, 2:27 am
I found a plugin "GPUInfo.dll" to get the info I need but I do not know if I can use it with Xwidget and if so I do not know how to make Xwidget use this DLL
thank you.
PostPosted: January 25th, 2017, 2:52 am
thank you.
This .dll is useless @Rom. No way that you can use it with XWidget. As I told you you need a third party program running in the background to get the info. I don't know if the Dev will add these extra tag codes (the version 2.0 is under development), but for now there is no other way.
PostPosted: January 25th, 2017, 3:00 am
I have a program in the background (GPUZ) but I do not know how to be able to recover the values ​​I need .... I am not a JAVA pro ...
Thank you
PostPosted: January 25th, 2017, 4:53 am
As I told you I don't know if will work with GPUZ. I don't remember if I had used this program or not, but I remember that it worked. Apply any of these 3 cores and check which tags are available for each one. Add a text and assign the various tag codes there.
With the third party program running on the background, press Debug in the designer to run your widget and see if it will show the value.
This is all you need to do!
XWidget will read the data automatically.
PostPosted: January 25th, 2017, 8:04 am
Then I try with the CORE AIDA64, I select the path of access in xwidget.
I configured my elements
like this
Select Core: Aida64Core1
FormatCoreData: GPU TEMP : %GPU1TempC°
But it does not work it only shows zero ... While I did the way for the CPU and it works ....
I use Aida64 Extrem Trial, its a problem ?
Thank you.
PostPosted: January 25th, 2017, 9:10 am
I can't test this particular core and I never used it. I had tested with the fan speed and temp and worked. But since they need third party programs I decided to not create any widgets with these cores.
Keep in mind that this happens ONLY with these 3 cores. ALL the rest work without any extra program installed.
I can't help you or tell you more..
PostPosted: January 26th, 2017, 2:55 am
no problem i think the Aida64Core doesn't work corectly...
After some research I notice that Xwidget considers that Aida64 is not running in the background while it is running ....
Here is the screen that shows it thanks to the tag "% Running" which marks me false ....
Users browsing this forum: No registered users and 7 guests
