It is currently April 23rd, 2024, 9:09 pm
PostPosted: December 23rd, 2015, 7:18 pm
When a layer is made opaque using the fadeto command:
aboutUsLayer.FadeTo(0,1);
- any links on the layer are still clickable. This is wrong. When a layer has an opacity of zero then it should equate to the following:
aboutUsLayer.visible = false;
In this case the layer is not visible so you cannot interact with it.
The fadeto command is incorrect in the way it operates allowing interaction with an invisible layer.
PostPosted: May 11th, 2017, 1:03 am
Workaround - To restore normal functionality you will have to change the layer visibility to false once the fadeTo has accomplished its task. The xwidget method of doing this is to use a synchronised timeout function:
aboutUsLayer.FadeTo(0,2); // xwidget code to fade the layer in two seconds
setTimeout("fadeDone",2000); //the timeout in milliseconds must match the fade measured in seconds.
//function that is called when the fadeout is completed
function fadeDone () {
