It is currently 2017年 May 24日 09:44
PostPosted: 2015年 Dec 9日 06:25
To capture the use of the ctrl key whilst using the scrollwheel I would use the following javascript code. See the event keywords in the code sample below:
backplate.onMouseWheel = function (event) {
var size = Number(preferences.scalePref.value),
maxLength = Number(preferences.scalePref.maxLength),
minLength = Number(preferences.scalePref.minLength),
step = 10;
if (event.ctrlKey) {
if (event.scrollDelta > 0) {
size += step;
if (size > maxLength) {
size = maxLength;
} else if (event.scrollDelta < 0) {
size -= step;
if (size < minLength) {
size = minLength;
preferences.scalePref.value = String(size);
resize();
What is the equivalent method to obtain the CTRL keypress within Xwidget?
Last edited by yereverluvinuncleber on 2015年 Dec 23日 16:28, edited 1 time in total.
PostPosted: 2015年 Dec 9日 06:33
Online
Check this widget and the script:
http://subhanulhaque.deviantart.com/art ... -339438490
This guy created a virtual keyboard..
PostPosted: 2015年 Dec 9日 07:17
Thanks Jim for the attempt to help.
Yes he did create a virtual keyboard but he didn't capture a CTRL key, his keyboard just has images that respond and add characters on a screen. There was no ctrl key and he didn't handle the event. Interesting widget though...
PostPosted: 2015年 Dec 9日 07:42
Online
I found this:
http://help.adobe.com/en_US/AS2LCR/Flas ... 00520.html
PostPosted: 2015年 Dec 9日 17:23
Let me see what I can do with it.
PostPosted: 2015年 Dec 23日 16:27
It seems that you cannot capture keypress events when manipulating any object other than an text edit box or similar. This is a problem as it means that a press of the CTRL key when the mouse is over the widget cannot be captured even though we have an onKeyDown event set up and code assigned. The event is simply ignored.
I tested a very large edit box at an opacity of 1 that can be set over the whole widget, this would have allowed a CTRL key to be captured, unfortunately mouse-through does not seem to work with edit boxes so all other onMouse events for all other images sitting below are negated when a large edit box is positioned above them.
So, to sum up: Xwidgets has an incomplete implementation of onKeyDown event that does not currently function on image objects. This is a BUG. Changing the title of this thread to a BUG.
PostPosted: 2017年 Apr 25日 05:23
BUMP:
This bug is a very serious one, it means that Xwidgets cannot respond to keypress events. That makes it useless for creating keyboard driven apps that respond to key events.
For example, when using youtube to display videos the spacebar, cursor and other keys can be used to control the video. These keypresses have become the standard for media players and allow the user to interact with the app using the keyboard if he wishes.
Xwidget does not allow this interaction due to a shoddy implementation of the keydown event.
Users browsing this forum: No registered users and 2 guests
