It is currently June 12th, 2025, 4:47 pm
 Post subject: Player using Winamp
PostPosted: April 3rd, 2015, 3:37 pm
I have an issue using Winamp with any player widget.
The player does not refresh the next current playing song for some reason. It stays on the previous track.
I can fix this by mousing over the widget and hitting f5. The correct now playing song title is then updated correctly.
Anyone else having this issue or can you suggest any tips to fix?
Appreciated.
Cheers, Pete
 Post subject: Re: Player using Winamp
PostPosted: April 4th, 2015, 4:53 pm
does anyone else have this issue?
It is still doing it unfortunately
Cheers, Pete
PostPosted: April 13th, 2015, 2:00 am
Problems with one widget?
Winamp is "officially" dead but still ... The time i was using I don't recall anything like this
PostPosted: April 13th, 2015, 2:34 am
nope. All player widgets. Seems to forget to change to next track info and only way to get it to update is mouse over widget and hit f5.
Winamp isn't dead. :-) It's still very alive and new version coming out soon..
Cheers, Pete
PostPosted: April 16th, 2015, 2:58 am
This seems to be solved now. It was a third party old plugin.
Thank you
Cheers, Pete
PostPosted: April 16th, 2015, 3:48 pm
NO. It still does it. It occasionally shows wrong song. An older one that was played. Surely someone else must have this issue too using Winamp?
Cheers, Pete
PostPosted: April 19th, 2015, 4:27 pm
ok I completely uninstalled the suspect Winamp Plugin and have not had an issue since.
(I had only disabled it before)
Cheers, Pete
PostPosted: April 19th, 2015, 11:28 pm
Can you name the plugin?
PostPosted: April 20th, 2015, 12:17 am
yep playlist file remover.
pm me if you want a copy to test. It's hard to find
Cheers, Pete
PostPosted: April 22nd, 2015, 5:30 pm
well it came back again.
So I remade my own player without seek/progress bar etc.
Just simple Artist - Song Name and time remaining.
No issues as yet.
I have a feeling the progress bar is the issue.
Maybe have a look at next release..could be a bug
Cheers, Pete
PostPosted: April 24th, 2015, 1:33 am
still doing it. I will post this in bugs area.
Cheers, Pete
Users browsing this forum: No registered users and 7 guests
