It is currently June 12th, 2025, 12:12 am
 Post subject: Edit script/Save ini
PostPosted: September 12th, 2014, 4:58 pm
Could you please help me adding the "save ini" part for this widget?
Read the comment by @koelo..
http://jimking.deviantart.com/art/gNow- ... -456869278
Thanks!
 Post subject: Re: Edit script/Save ini
PostPosted: September 16th, 2014, 3:49 am
it's ready:
gnow_weather [test] [2014.09.16]1612.xwp [305.35 KiB]
Downloaded 244 times
PostPosted: September 16th, 2014, 4:10 am
Thanks! :D
I think that the topic about "save ini" and similar script should to be updated with extra info and the most important make it much more simple and understood for the novice users, or for people that don't know a lot about script....
viewtopic.php?f=10&t=2316
Ok, for example now with your help I can "copy" or make a similar script next time but a good and simple tutorial will be great..
Users browsing this forum: Bing [Bot] and 9 guests
