It is currently October 23rd, 2026, 2:55 am
 Post subject: Help "Downloading image"
PostPosted: May 27th, 2014, 4:23 pm
hey, im trying to make a daylight map widget, how do i pharse and automatically download an image (jpg, bmp, gif) to a destination folder?
-George Carlin
PostPosted: May 27th, 2014, 10:36 pm
there is a function available for this:
DownloadFile("","","")
the parameters are as follow:
1. url: the url where you want to download from
2. FileName: the path and file name where you want to store the file
3. FunctionName: the function which should be run after the download completed (you can use this to use the downloaded file), you must fill this parameter with a function name to function work
the FunctionName that will be called after download completed
will have these parameters:
function dlCompleteExample(p1,p2,p3)
p1: will indicate that the download is succeeded (true) or failed (false)
p2: will store the path to the file
p3: will get the size of the file
Notes:
1. you can use your own FunctionName
2. you can use your own parameter names as variable instead of p1,p2,p3
3. using of parameters is optional
example:
function widgetOnLoad()
   DownloadFile("http://bbs.xwidget.com/styles/subsilver2/imageset/site_logo.gif",WidgetPath+"download_test.gif","dlComplete")
function dlComplete(stat,fpath,fsize)
   print("status: "+stat)
   print("file path: "+fpath)
   print("file size: "+fsize)
more info can be found here:
http://bbs.xwidget.com/viewtopic.php?f=8&t=1966
http://bbs.xwidget.com/viewtopic.php?f=8&t=3632
PostPosted: May 28th, 2014, 12:43 am
Great reply hamid :mrgreen:
PostPosted: May 28th, 2014, 6:54 am
Thank you hamid! :D
-George Carlin
Users browsing this forum: Bing [Bot] and 94 guests
