It is currently June 12th, 2025, 10:47 pm
 Post subject: count down timer
PostPosted: November 13th, 2013, 2:28 pm
is it possible to be created? to put some time for example 2 minutes and count down and to the end to play a sound
 Post subject: Re: count down timer
PostPosted: November 22nd, 2013, 8:21 am
download the attachment and add it to xwidget.
after you run this widget, add your number to the EditBox and press enter to start timer
timer.XWidgetPkg [45.35 KiB]
Downloaded 488 times
PostPosted: November 22nd, 2013, 10:21 pm
very nice thanks man... now i might make some changes to view of widget colours size these things..
Users browsing this forum: No registered users and 6 guests
