It is currently June 12th, 2025, 7:56 pm
 Post subject: Using remote images
PostPosted: October 14th, 2013, 5:42 am
Trying to use a remote image in an image control... Help needed. Anyone? Tried to use the download file but that didn't work.
 Post subject: Re: Using remote images
PostPosted: October 14th, 2013, 10:17 am
Could you pls be more clear DG? What exactly do you want to do...?
PostPosted: October 15th, 2013, 4:56 am
Stuck with that flickr weather one...
I got the url of images from the server (something like : http://example.com/image.jpg). Now i have to download and display them in an image control. But the code for downloading "downloadfile()" is not working. So is there another way of downloading or displaying them?
PostPosted: October 15th, 2013, 6:39 am
I see! I didn't realize that was for my request! :lol:
Come on guys help us with this..!
PostPosted: October 15th, 2013, 1:16 pm
This seems to work, does it help ? (credit to KJags for similar post ;) )
var url = "http://blog.marketing.ai/wp-content/uploads/2013/04/Link.jpg"; // whatever your url is to the image.
var file = WidgetPath+"Link.jpg"; // save location and file name
function button1OnClick(Sender)
DownloadFile(url,file, "UpdateImage"); // run function after download
function UpdateImage()
image1.Src = "";
image1.Src = file; // update the image
PostPosted: October 16th, 2013, 6:06 pm
Thanks meme... Looks like it will do the job. But isn't there any way to know whether the file was successfully downloaded?
PostPosted: October 16th, 2013, 9:33 pm
Maybe, delete the file with
DeletFilesToRecycle(file,0);
then download the file
then in function UpdateImage() (because this seems to execute after the download is complete) check if the file exists with
FileExists(file);
If the file exists the download was successful.
PostPosted: October 16th, 2013, 11:41 pm
Thanks a lot!
Users browsing this forum: No registered users and 6 guests
