It is currently June 12th, 2025, 3:08 am
PostPosted: October 9th, 2013, 6:59 am
I'm using the "Msg (,)" as taught me meme. Very good!
I came another problem: I want to send a text from the widget "A" (from "edit1") to the widget "B" (to "text1).
How I can do this???
thank you!
PostPosted: October 9th, 2013, 7:56 am
You will need some custom code handler to segregate the message. Like a message such as : FROM<EDIT1> TO <LABEL 1> <DO SOMETHING>. Then define a regex that parses the controls and does the job
PostPosted: October 9th, 2013, 8:38 am
Ups!, thanks digigamer!!!... but since I'm not professional of codes... (just hobbyist)... I would not know how to do all that you suggest :(
that's the ugly part of being only "designer" :)
PostPosted: October 9th, 2013, 11:02 pm
Try this...
In the sender widget
function button1OnClick(Sender)
msg("content","receiver"); // content = the text message you want to send, receiver = the name of the widget receiving the message
In the receiving widget
function widgetOnMsg(MsgString)
text1.text = MsgString; // MsgString equals the content you sent ( the text message ) use it as you like in the receiving widget
PostPosted: October 10th, 2013, 5:56 am
YES! this works!
but I want to send action msgs to the same widget, then I done this (some friend of mine helps me)
Each "case" are other orders that I send from main widget to the remote widget trough "msgstring".
The default action is below, at bottom, in red.
var posi = 99
var nom = "nameguy"
var subnom = "titlespeech"
switch (MsgString)
case "editlower":
layer1.ScaleTo(0.5,0.5,1,0,2,9);
widget.top = 350;
widget.Left = 30;
break;
case "putlower":
layer1.ScaleTo(1,1,1,0,2,9);
widget.top = 1000;
widget.Left = 1800;
break;
case "downname":
text7.Font.Size = text7.Font.Size -2;
break;
case "upname":
text7.Font.Size = text7.Font.Size +2;
break;
case "zoom1":
break;
case "zoom2":
layer1.ScaleTo(0.7,0.7,1,0,2,9);
break;
case "zoom3":
layer1.ScaleTo(2,2,1,0,2,9);
break;
case "uptitle":
Titulo.Font.Size = Titulo.Font.Size +2;
break;
case "downtitle":
Titulo.Font.Size = Titulo.Font.Size -2;
break;
case "lowerout":
image4.ScaleTo(1,1,1,0,2,9);
image4.MoveTo(20,22,2,1,9);
image1.moveTo(-1280,0,2,0.5,6);
logo.moveTo(-310,0,2,0.5,9);
sleep (500);
break;
case "lowerin":
sleep(500);
logo.moveTo(-60,0,1,1,8);
sleep (400);
image1.moveTo(88,0,1,1,8);
sleep(500);
image4.ScaleTo(1.7,1.7,2,0,1,9);
image4.MoveTo(-140,22,1,1,9);
break;
default:
posi = MsgString.indexOf(";")
nom = MsgString.substring(0,posi)
// this "substring" is for send some part of the text to another place (to "title.text")
subnom = MsgString.substring(posi +1,MsgString.length)
text7.text = nom;
title.text = subnom;
break;
PostPosted: October 10th, 2013, 1:25 pm
would this work for your actions by using if statements ?
function widgetOnMsg(MsgString) //Message code in the remote widget
if(MsgString=="close") // remote close, action 1
close(); //action 1
if(MsgString=="hide") // remote hide, action 2
widget.visible=false;
if(MsgString=="show") // remote show, action 3
widget.visible=true;
PostPosted: October 10th, 2013, 8:22 pm
Well, I'm a professional! Next time, I'll see that I'll put some code. :mrgreen:
Users browsing this forum: Bing [Bot] and 9 guests
