It is currently October 23rd, 2026, 7:52 am
 Post subject: Button Function
PostPosted: June 20th, 2013, 10:53 pm
I have created a button in Xwidget and I want that when I click it, it should perform same function which is performed when you press [Start]+[Tab] on the keyboard......
::Innovating The New::
 Post subject: Re: Button Function
PostPosted: June 25th, 2013, 5:30 am
Hi, You can sent key with script ,etc:
var WshShell = new ActiveXObject('WScript.Shell')
WshShell.SendKeys('{F1}');
PostPosted: June 25th, 2013, 7:42 am
Thanks, it works well for function keys but it did not work for start, tab, Ctrl,Alt buttons etc...
PostPosted: July 5th, 2013, 12:13 am
Hello.
I have the same problem. Would you, please, tell me how to set the hotkeys "Win+B+Enter" on a button correctly? I need a script or is it possible to do via suggested? !KeyInput=91 (just winkey) processed correctly, but I need a combination.
Alternatively, does anybody know how to derive corresponding functions from user32.dll set them to buttons?
PostPosted: December 4th, 2013, 2:28 am
Sending Keystrokes to a Program:
http://technet.microsoft.com/en-us/libr ... 56592.aspx
it only doesn't work for [win-key]
but it works for other keys.
Users browsing this forum: No registered users and 75 guests
