It is currently 2018年 Jan 16日 20:50
PostPosted: 2017年 Nov 24日 08:16
Hello
I would like to create a ProgressBar to set the transparency of some of my layers how to do it, I try several code but without success .... If someone little enlightened I am a taker :)
Thank you :)
PostPosted: 2017年 Nov 24日 10:52
Hi Rom. I don't know the answer but I'm pretty sure that a java script exists for something like this..
If someone replies here, it will be great for you and for the rest, but if you don't find a solution you can always do it in another way, not so 'professional' but with a similar function. You can create a number of layers or images (better) that they have a different transparency and then with right click selections, you can make them selectable hidding the other ones.
Just an idea... :)
Example
https://jimking.deviantart.com/art/Weat ... -655218106
PostPosted: 2017年 Nov 24日 11:00
Thank you for your reply.
I try several things like that.
I linked my Layer to a text that set transparency to 50 and it works. here is the code in question.
function textOnClick(sender)
Layer.Opacity=0.5;
So I thought I could do the same thing with a progressBar
PostPosted: 2017年 Nov 24日 12:37
That's why I gave you an example in case that you can't do it through script. ;)
