It is currently June 13th, 2025, 10:54 am
 Post subject: Net blinking funtion?
PostPosted: June 5th, 2013, 6:06 pm
I'm creating a net widget. I have two kind of arrows with different colours (png files) and I want to use them as one like this:
Flash up when "reading", so when is active the download or upload. Is it possible...???? :roll:
PostPosted: June 6th, 2013, 3:54 am
Same question by Cov:
viewtopic.php?f=8&t=3194
PostPosted: June 6th, 2013, 2:46 pm
This seems to work
function netmonitorcore1OnUpdate(Sender)
var NetInCheck = netmonitorcore1.get("%NetinSpeed");
if(NetInCheck.charAt(0) == 0)
text4.Text = "False"; // change image color to suit no download data flow
else
text4.Text = "True"; // change image color to suit download data flow is active
var NetOutCheck = netmonitorcore1.get("%NetoutSpeed");
if(NetOutCheck.charAt(0) == 0)
text3.Text = "False"; // change image color to suit no upload data flow
else
text3.Text = "True"; // change image color to suit upload data flow is active
PostPosted: June 6th, 2013, 3:22 pm
Thank you meme, but this code seems to be taken from a specific widget that is different from mine...
I wanted to use 2in1 images that will alternate depending of the activity...
But thank you anyway! ;)
PostPosted: June 6th, 2013, 3:59 pm
Hi jimking
I was aware you wanted to change the image but not sure or its exact location or name.
So I wrote this code and thought you would just modify the lines "// change image color" to toggle the images you are using.
Happy to assist if you provide a sample. :)
PostPosted: June 7th, 2013, 1:08 am
Hi jimking
Hope you don't mind, I modified your "glass_(vclouds)_net" widget so the arrows change to yellow when uploads or downloads are active.
Not the method you mentioned but the effect is the same, its hides the yellow arrow when no traffic is detected.
What do you think :?:
File comment: "glass_(vclouds)_net" with code
glass_(vclouds)_net.XWidgetPkg [88.86 KiB]
Downloaded 360 times
PostPosted: June 7th, 2013, 2:53 pm
I wonder why the values for transferspeed differ so much: click
PostPosted: June 7th, 2013, 3:01 pm
Hi Cov
Make sure you only have one xwidget running at a time that is monitoring net traffic otherwise the values are not accurate, try each one separately.
Also I noticed in this widget the upload and download speed text is not bound to a core, it should be to netmonitorcore1
Maybe if you want to run another widget with out interfering with the values then use netmonitorcore2 in the second widget.
PostPosted: June 7th, 2013, 3:12 pm
Hi meme,
I just closed down another widget (Simplicity) for monitoring net traffic and it really made a difference.
However, I still had the Chameleon Glass (Windows standard) gadgets open at the same time.
In comparison to the windows standard gadgets, the values of the xwidget were very unsteady, flickering up and down.
Can there be any settings changed to make the numbers more steady?
Thanks
