It is currently October 23rd, 2026, 1:17 am
 Post subject: Help with Round Corners.
PostPosted: September 10th, 2012, 2:32 am
Is there a way to check/uncheck the round corners via script? An example would be:
function widgetOnLoad()
  backboard_small.Corner.Corners.BottomLeft.Checked = true;
  backboard_small.Corner.Corners.BottomRight.Checked = true;
Thanks in advance.
PostPosted: September 10th, 2012, 3:53 am
Well i have to admit that was a challenge, i had to go back 4 the old school stuff and learn over again bit-wise operations 8-) , and it was totally worth it (Help me with one of the game im witting now)
Shortly use this function to convert 4 Boolean to an integer.
/** Written by vlad. Contact me for question or help at http://4ybak47.deviantart.com/
convertCornersToInt( [topleft] , [topright] , [buttonleft] , [buttonright] ).
Example : object.Corner.Corners = convertCornersToInt(true,true,false,false);*/
function convertCornersToInt(tl,tr,bl,br)
    return tl | tr << 1 | bl << 2 | br << 3;
If you wish some explanations here is my code while i was testing the function above. 8-)
//print(true << 2);
//convertCornersToInt(true,true,true,true);
//print(convertCornersToInt(true,false,false,false));
//Works!!!
////widgetContainer.Corner.Corners =  convertCornersToInt(false,true,false,true);
**function usage Example :
//Curve only the top two corners.
**Variables:
//tl - topleft       : Boolean [true / false]
//tr - topright      : Boolean [true / false]
//bl - buttonleft    : Boolean [true / false]
//br - buttonright   : Boolean [true / false]
         //obj.Corner.Corners = "topleft,topright,buttonleft,buttonright";
         //printBinary(4);
         //printBinary(15);
         // var b = true;
         //printBinary(b ? 1 : 0);
         //printBinary(cb2i(true));
         //printBinary(tl);
         // tl = 1,   tl << 1 = 10,     tl << 2 = 100,     tl << 3 = 1000
         //printBinary(cb2i(tl) << 2);
//Usage : check the binary value of the number n.
function printBinary(n)
    print("~~~~~~~~~~~~~~~~~~~");
    print("   Binary ( " + parseInt(n).toString(2) + " )");
    print("   Number ( " + parseInt(n).toString() + " )");
    print("   Value  ( " + n.toString() + " )");
    print("~~~~~~printBinary~~~~~~");
//Convert boolean to int / binary [1,0]
function cb2i(bool)
    return bool ? 1 : 0;
PostPosted: September 10th, 2012, 3:58 am
Wow. Thanks dude. It helped me a lot O_O I could've never figure this out on my own -_-
PostPosted: September 11th, 2012, 3:14 am
backboard_small.Corner.Corners =0(disable corner)
                               =1(TopLeft)
                               =2(TopRight)
                               =3(TopLeft + TopRight)
                               =4(BottomLeft)
                               =7(TopLeft + TopRight +BottomLeft)
                               =8(BottomRight)
                               =15(TopLeft + TopRight +BottomLeft + BottomRight)
PostPosted: September 11th, 2012, 3:30 am
Thanks qiancang but the script vlad gave me seems easier to use and less likely to bug.
Users browsing this forum: No registered users and 97 guests
