It is currently October 23rd, 2026, 3:21 am
PostPosted: August 29th, 2012, 7:57 am
Hi! I want to know what it's "Aida64/Everest" Core :?:
Thanks!
Armando
PostPosted: August 31st, 2012, 1:29 am
GPU (Graphic Processing Unit ) - or simply the monitor for your video card.
PostPosted: September 1st, 2012, 12:47 am
Hi,You need install and open the Aida64/Everest ,and then you can add a Aida64/Everest Core in XWDesigner,then you can get CPU/GPU Temp information
PostPosted: September 3rd, 2012, 1:08 pm
Vlad and Tony: thanks you very much!!!
Armando
PostPosted: September 11th, 2012, 9:08 pm
Hi guys!
I have Aida64 Extreme Edition version 1.80.1450 installed on my PC. My question is what info/details that this core can retrieve from the Aida64 program (besides the aforementioned CPU/GPU temp)?
Can the Aida64 core retrieves info from the items list in the OSD/Vista Sidebar (which can be found in Aida64 program's preferences)?
PostPosted: January 16th, 2013, 11:28 pm
Hello, people.
I know this topic is old (September 2012), but I want to clarify this in case it helps others.
For the AIDA64/Everest module to work with xWidget, AIDA64/Everest needs to be properly configured. Specifically, it has to be checked the option Enable Shared Memory in the section Hardware Monitoring/External Applications. Look at the image.
There you can find more than 70 different values to be displayed with xWidget.
Cheers!!
Users browsing this forum: Bing [Bot] and 112 guests
