It is currently 2018年 Feb 22日 20:35
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: 2012年 Jun 10日 08:42
XLaunchpad 1.08 Release now available (2013-5-18)
XLaunchpad - Mac OS X Lion Launchpad for Windows
[Information]
XLaunchpad gives you instant access to all your shortcuts.Arrange apps in XLaunchpad any way you like by dragging icons to different locations or by grouping apps in folders. Simply drag one icon over another to create a folder. you can name the folder whatever you like when you open the folder.
Homepage: http://www.xwidget.com
Update log: http://www.xwidget.com/ver_xlp.html
Download: http://www.xwidget.com/download_xlp.php
Portable version : http://www.xwidget.com/download_xlp2.php
Freeware
Version: 1.0.9.518
Updated: 5/18/2012
Requirements: WindowsXP/Vista/Windows7/Windows8
[Virus Scan reports]
There are some antivirus software false positives, this is a virus scan report,It is clean.
http://r.virscan.org/report/bf7209887fa ... 34176.html
http://r.virscan.org/report/e7173858c4d ... cf40d.html
Please check this virus scan report by Avira, It is CLEAN:
http://analysis.avira.com/samples/detai ... id=1224419
http://analysis.avira.com/samples/detai ... id=1149790
[Video]
http://www.youtube.com/watch?v=Nyr5mrX64kg
http://www.youtube.com/watch?v=uMHX-GGuZU4
[Update log]
v1.0.9 2013.5.18
Add: Auto Backup When Exit Application
Add: Tray icon popup menu add item "Backup/Restore"
Fixed: crashes when click close button to delete some shortuct
Improved stability
v1.0.8 2012-7-31
Add: Scale Animation Effect when Mouse click icon
Add: Option of "Enabled Scale Animation Effect when Mouse click icon"
Fixed: Background Blur function Sometimes does not work or popup error
Fixed: Restore the right-click menu "Add-File/Folder" menuitems
Improve: When the display number is changed will automatically reload
Add Language pack: Traditional Chinese, Japanese , Latvian , Vietnamese
v1.07 2012-5-24
Add: Right click menu add "Add--Window Mode", You can check it when you need drag and drop to add file or folder or URL to XLaunchpad
Add: Right click menu add "Add--Web URL"
Add: Support drag and drop URL link from Web Browser into XLaunchpad to add shortcut of URL
Add: You can input URL into shortcut setting's path to open URL
Add: Add "options" command line to open Options window
Fixed: White Background When resume from sleep problem
Fixed: Lost focus when close option window problem
Improve: Max line EveryPage from 8 to 15
Improve: Improve the response speed and fluency with Max Memory mode
[Planned Features]
--Synaptics touch support
--Special Folders "Desktop" to Synchronize the desktop files and icons
--Recycle Bin icon auto detect full and empty
--Support XWidget's widgets and custom them
[Thanks]
Piratz made video for XLaunchpad
HPJ Greman Translation
PostPosted: 2013年 May 17日 04:44
[Update log]
v1.0.9 2013.5.18
Improved stability
Users browsing this forum: No registered users and 1 guest
