This is the Yahoo widget version of the OHM gauge that calls the script above, which in turn was taken from the Xwidget OHM gauge.
This Yahoo widget is a perfect example of running Jscript from the command line.
Feel free to open the widget and view the code for comparison purposes and to see how it is done. You'll see the code is very much the same as the Xwidget.
Tony could easily take the above code and adapt it and incorporate it into an OHM core.
Attachments: |
File comment: New version - Previous Yahoo version of widget was downloaded 6 times
Panzer OHM gauge Ywidget.zip [2.92 MiB]
Downloaded 224 times
