It is currently June 14th, 2025, 8:20 am
PostPosted: March 11th, 2017, 4:42 am
Xwidget, the desktop widget design tool, uses javascript as its scripting language (along with vbscript) however, scripting in the Xwidget engine is merely used as glue between the IDE and the cores to allow users to customise the extra functionality that is provided by 'cores' or external data sources.
This is an unsatisfactory approach that means the scripting in Xwidget will never receive the attention it really requires leaving the scripting as the poor relation with regard to developing actual programs. Without the ability to extend widgets ourselves through scripting, more cores need to be written to allow access to new and fresh data sources but these are closed-source and written in C++ and without the main developer being available 100% of the time the existing cores will degrade over time (generally stop working in relation to their changing data sources) and new cores have been proven to be very slow to arrive.
If the xwidget environment is ever going to be considered as a serious contender for real widget development it MUST incorporate one of the main javascript engines that are available that follow ECMA standards as defined by the ECMA body: https://en.wikipedia.org/wiki/ECMAScript
If Tony, the Xwidget designer was to incorporate a modern 3rd party open source engine (there are several available that others incorporate into their engines) and simply make the additional xwidget functions available to it (via cores) then it would allow developers to use either xwidget's cores or build their own functionality in javascript. It would open the xwidget engine to the world of javascript that is already extant. Hundreds, if not thousands of javascript programs would then be able to run within xwidget. Potentially, most if not all the code that you create for Xwidget would become available to the web.
Feature Request: incorporate ECMA 1.4 javascript (or later version) into the new Xwidget 2.0 environment and watch Xwidget mature into a real widget programming environment.
http://duktape.org/ Duktape is such an embedded environment usable from C++. It would truly transform Xwidget from a toy to a serious tool.
Last edited by yereverluvinuncleber on June 28th, 2017, 5:38 am, edited 2 times in total.
PostPosted: April 13th, 2017, 2:23 am
XWidget depends on Windows Script Host (which unfortunately supports ES 3) There is no way to replace it. What you can use is write ES5/6/7 code and use a transpiler like babel and compile it to ES3 compatible code.
Xwidget can however replace the javascript engine (V8, the one that runs in Google Chrome is really easy) but it will render a whole class of widgets unusuable, i.e, the ones that depend on Microsoft ActiveX.
PostPosted: April 20th, 2017, 3:25 am
I hear what you are saying with regard to ActiveX Digigamer. It is complex.
I am just thinking of cross-platform compatibility and code re-use.
Other widget engines use alternative javascript engines but manage to expose the activeX APIs successfully. Obviously this does not allow cross-platform compatibility but would retain the windows functionality.
Users browsing this forum: Google [Bot] and 11 guests
