It is currently June 14th, 2025, 7:49 am
PostPosted: April 14th, 2016, 4:30 am
Using the coretemp core the naming of the core tags in the widget designer is incorrect and misleading.
%CPU1Core1Temp extracts information from core 0 not core 1
%CPU1Core2Temp extracts information from core 1 not core 2
%CPU1Core3Temp extracts information from core 2 not core 3
%CPU1Core4Temp extracts information from core 3 not core 4
Cores should always be named 0-2, 0-4 or 0-8 depending upon how many cores your cpu has.
On top of that, the tag %CPU1Core4Temp is not even mentioned in the dropdown list of tags in the designer. %CPU1Core0Temp does not work.
The use of the tags as named at the moment can be confusing and lead to incorrect results being displayed. These tags (same as many others) do not seem to be well documented. This will hopefully help in that respect.
Just before Jim pops in and says it is all a matter of opinion, coretemp reports temperatures for core 0 and Xwidgets tag for that core is %CPU1Core1Temp... there is an inconsistency here, 1 is not 0, Xwidgets is at fault, it needs to be consistent with coretemp - BUG.
