It is currently June 12th, 2025, 4:44 am
PostPosted: July 14th, 2014, 3:51 pm
I have this issue:
Exactly what I notice: The widget is loading two specific tracks from my pc and when press "play" the buttons,progressbar doesn't work, doesn't play anything. Even when I add other song, only shows/loads the same track but actually not play anything..
Close the widget, restart XW, reboot windows, the widget always load the same stupid track..
After some search I discover that there is a conflict with XW and WMP.
The XW that trying to play , the WMP see cannot them:
Can not find the file from the Windows Media Player. If you attempt playback, recording, or sync an item in your library, the item may result in a file that has been moved, renamed or deleted.
So I select the option to remove them from the Library. But when I open a music widget, XW tries to re-play these tracks, so the widget is stuck and the most important these "invisible" tracks APPEAR AGAIN ON THE WMP's playing list!!!!!
HOW CAN I RESOLVE THIS...????????? :|
PostPosted: July 14th, 2014, 4:04 pm
After the 3rd attempt I selected the option of the WMP to clean the whole library files. After that FINALLY XWidget works again!! :D
PostPosted: October 21st, 2014, 10:39 pm
On widget exit
do this.
SetValue("playercontrolcore1.WMPPlaylist","")
SaveValue();
Users browsing this forum: No registered users and 10 guests
