It is currently June 14th, 2025, 8:29 am
PostPosted: October 26th, 2013, 1:08 pm
[Bug & Suggestion] for Aligning & Positioning & Resizing
Bug:
1. [if Auto-Resize is not checked] Aligning objects to most of the available options will automatically resize the object
>it shouldn't change the size of object on Aligning
ex:
-top > resizes width of object to max
-right > resizes height of object to max
-and so on...
2. Choosing Scale in aligning options of object will change the size and position of object on next start (Specially when more than one object have scale aligning option enabled)
>Scale should be in Resizing options & not in aligning option
>an object should have option to aligning to somewhere and scalability at the same time
Suggestion:
1. Positioning object by using position of another object (Distance from object)
> selecting between [normal positioning] & [distance from another object]
> Select an object from dropdown
> and enter distance (x,y) from the selected object
2. Aligning to another Object
> Selecting Object from dropdown
> Choose Aligning methode
3. Checkbox for locking size of Object (to prevent Auto-Resizing & Resizing by mistake)
Users browsing this forum: No registered users and 10 guests
