It is currently June 14th, 2025, 8:17 am
PostPosted: October 26th, 2013, 11:47 am
XWidget 1.8.4
> PhotoAlbum Core
Brief:
1. "!Prev" doesn't work
2. [Album Setting > Random Order] doesn't work correctly
3. [Album Setting > Include Subdir.] doesn't work correctly
MoreInfo:
1. "!Prev" command doesn't do anything; no matter assigned to menu, button,...
2. if i check [Random Order] it will play randomly (as should be) but if i uncheck it, it doesn't go to next picture in the list
3. no matter checked or unchecked [include subdir.]; it doesn't have any effect; it will always play subdir.s (by default)
PostPosted: November 26th, 2013, 12:05 am
Please update to the last version. I never had this kind of problems with photo core in 1.8.4 and with any version. Could you pls post your widget? Maybe you're missing something...
PostPosted: November 26th, 2013, 1:27 pm
i have used Eker Photo Album inside XWidget package.
also for my own widget doesn't work.
1. for !Prev it will go !Next
when you go !Next and then !Prev it will go to another file. (but it should go to file u just seen)
if you use %FileName & %PrevFileName & %NextFileName you will see that it goes to next file in the list.
(i should note that i have tested now & it only happen for Random mode)
2. if you uncheck [Random Order] it doesn't play anymore
(i should note when you have selected a source that have sub-directories)
it will work correctly for one directory.
3. if you uncheck [Include Sub-dir] it still view sub-directories. (so no difference you check or uncheck [sub-dir])
i'll check with new version later and post again
PostPosted: November 26th, 2013, 1:46 pm
Please upload here your widget to check it..
I repeat using the photoalbum core don't see any problems.. But let me see your xwidget.. I need to check from the "inside"..
PostPosted: November 26th, 2013, 2:24 pm
it should be from core & not from widget.
anyway here's the widget from Xwidget package.
ekergallaryview.XWidgetPkg [42.01 KiB]
Downloaded 336 times
PostPosted: November 26th, 2013, 2:42 pm
About the number 1, if the Random is checked is logical that the prev/next will don't show the same images.
For the other two yes I confirm that there is a bug. To be honest I always use the Random option and that's why I didn't notice the problem..
Also I always select a clean folder with images without subfolders.
Anyway thank you for your report. It's up to the Developer to check it now.
But if you leave the Random option on your widget is work ok. Surely there is bug but is not a big deal for me...
PostPosted: November 26th, 2013, 3:11 pm
(for bug#1)
(with random Order enabled)
if i use %PrevFileName & %NextFileName Tag in widget and call !Prev command to load %PrevFileName it will load %NextFileName.
although PrevFileName was available in the core but it won't use it.
i think it should do one of these:
1. if it has a list of files so it always have previous files to go back.
2. if it doesn't have a list; it has last prevfile so it could load it and make %PrevFileName empty; so it go back one time and then do nothing
(for bug#2)
RandomOrder=Enabled & IncludeSubdir=Enabled //works correctly
RandomOrder=Enabled & IncludeSubdir=Disabled //doesn't work correctly (Still Included Subdirs)
(for bug#3)
RandomOrder=Disabled & IncludeSubDir=Enabled //doesn't work correctly (doesn't included Subdirs)
RandomOrder=Disabled & IncludeSubDir=Disabled //works correctly
i noticed that in my first report it doesn't play at all because my root directory was empty and all my images in SubDirs, and it doesn't go to subDirs even with SubDirs Enabled.
so this problem is also come from IncludeSubDir.
i tested XWidget 1.8.8 and the problems still exist
Users browsing this forum: Google [Bot] and 15 guests
