It is currently June 12th, 2025, 12:23 am
PostPosted: October 26th, 2013, 10:58 am
Xwidget 1.8.4
>NetMonitorCore
Brief:
1. %NetOutPercent doesn't have correct value
2. Refresh Interval Changes doesn't Save
3. NetIn & NetOut Values are not accurate
MoreInfo:
1. %NetOutPercent always show 0 for no usage & 100 for any usage (While i have set MaxNetOutSpeed to 30 and my usage is only 100-500 bytes/s)
2. Refresh Interval is Changable in the Core Settings but it doesn't have any effect when run it & when come back it fall back to its default value (1000ms)
3. i have installed Networx Program (a program to display Network Statistics) and NetMonitorCore values copmpares to it are different; also if i run more widget of same, the values of widgets are different with each other; also it most of the times misses network activities in bytes.
PostPosted: October 26th, 2013, 11:10 am
Read this:
viewtopic.php?f=3&t=3120
(works ok when you use txts)
PostPosted: October 26th, 2013, 11:58 am
jimking wrote:
Read this:
i'm sorry but i don't understand it,
where to use txts?
and works ok with which of the problems?
can you explain more plz?
PostPosted: October 26th, 2013, 12:31 pm
Confirming - only have one xwidget running at a time that is monitoring net traffic otherwise the values are not accurate, try each one separately.
I did notice a change in values when I upgraded from Win 7 to Win 8. This seem to only effect Xwidget - NetMonitorCore widgets, other programs remained unchanged.
PostPosted: October 26th, 2013, 2:07 pm
hamid wrote:
jimking wrote:
Read this:
where to use txts?
I mean that using txt with netcore the values seem to be ok. The problem exists when you use %percent code with rotator, roundline, chart and pie components. That's because the % is not actually corrisponding at the real % value. Please check the link that I added and you'll understand what I mean..
PostPosted: October 26th, 2013, 3:51 pm
1.
thats not true,
i have tested with both text and chart and both have the same incorrect value
i should mention that the "%NetInPercent" is having correct value but "%NetOutPercent" have the problem (having 100 value in text) and only can be lower than 100 if i change the MaxNetOutSpeed in the core to something so higher (about x10000 higher)
it should be a problem with "%NetOutPercent" formula; because when i use "(netmonitorcore1.get("%NetOutSpeedK")/netmonitorcore1.MaxNetout)*100;" in the scriptEditor it works ok.
2.
Refresh interval can't be saved
3.
not so accurate values for "NetIn" & "NetOut"
>can be because of refresh interval of 1s (that can't be changed) and missed progress of network in the period of a second.
"networx" program showing accurate values in progress and if comparing with each other you can see that NetMonitorCore have upper and lower values and also misses to show some low activity of network when in bytes.
also if i open 2 or 3 or... of that widget the values doesn't match eachother and every widget show its different values
>this could be because of it capture the value on that specified second but it should take average of values of that second
networx is freeware and have portable version; and if you would like to compare it here's the link:
http://www.softperfect.com/products/networx/
PostPosted: October 26th, 2013, 4:18 pm
Yes, I agree and surely the code needs optimization.. Let's hope that the Dev will fix it in the next version/s..
PostPosted: October 26th, 2013, 7:15 pm
As well as accuracy another nice feature would be -
Posted: 2012 Aug 12 Is there any way the NetMonitorCore could have a selection to monitor only internet data traffic and not include the local network traffic as well, could the NetMonitorCore monitor internet only ?
Reply by Tony
Thanks for your feedback, I had plan to add traffic source select for NetMonitorCore in furture version
PostPosted: March 17th, 2018, 7:35 am
Jim, Can you please ensure these three bugs are added to the list.
PostPosted: March 17th, 2018, 8:06 am
Added..
PostPosted: March 17th, 2018, 9:46 am
Thanks!
The refresh interval being locked to 1000ms causes performance issues on low power systems the interval being too frequent on gauges that use a switch animation on a rotating pointer.
I would suggest that you rate no.2 as MEDIUM
Users browsing this forum: No registered users and 6 guests
