It is currently June 14th, 2025, 12:04 am
PostPosted: August 8th, 2013, 4:06 am
The grab lines in the IDE that allow you to resize a portion of the screen, for example the grab line that controls the size of the cores that this widget uses - they are simply too thin. It is almost impossible to grab the things with the cursor/mouse and you have to be so precise in your movements before the grab symbol pops up. They need to be 4-5 pixels wide as per other editors,the certainly need to be wider so that they are easier to grab.
PostPosted: June 28th, 2017, 7:08 am
The bottom grab line has been expanded to incorporate the whole bar, this is an improvement, however the left hand grab bar is still miniscule and hard to grab.
