It is currently June 13th, 2025, 10:39 pm
PostPosted: May 16th, 2013, 11:56 am
Please Tony on the next version:
- Change the add song option and give us the possibility to add more than one songs!
- An "Add/Play folder" will be great!
- Add compatibility with "The KMPlayer". Is one of the best players and should be on the list!
At the end please fix this bugs: :!:
- After add a song the "play" is not working immediately and it needs to press "next" or "previous" track to start playing!
- When close the Player/Widget the player continues to play!
Also even when the player closed, when try to open it with Designer, memorizes the last playing track and this bad because causes freezing of the Designer. So the player is closing should NOT store any settings!
This causes also a jpeg#53 error when selected the cover image on Designer after I used the player.
Thank you
