It is currently June 12th, 2025, 3:22 am
 Post subject: AM/PM with png files
PostPosted: April 8th, 2013, 1:43 am
Tony, is possible to edit somehow the dateclock code so the png image files will have the same funzionality when used for 12h clock and am/pm files?
What I mean: Using text for the digits when it changes from 24h to 12h, the am/pm dissapear, but with png files not.. For example
24h clock: 13 : 56
12h clock: 01 : 56 pm
This is not possible using png files.... I hope to be clear.
 Post subject: Re: AM/PM with png files
PostPosted: April 8th, 2013, 3:37 am
3 png files named 12hr.png , 12hr0.png and 12hr1.png , set coredata tag as 12hr%AP01.png
ampm.XWidgetPkg [10.26 KiB]
Downloaded 294 times
PostPosted: April 8th, 2013, 12:35 pm
Thank you qiancang for the info! But at the end it seems more easy to make a text file for am/pm.. :)
