It is currently June 12th, 2025, 1:12 am
 Post subject: icons and weather
PostPosted: March 5th, 2013, 3:42 am
Many times when I make a new weather widget, is difficult to synchronize the icons with the weather.... :(
I use the numerical or with txt pngs but I don't know why the weather results with the wrong icon.... I also made this test:
I used the default icons from a working weather widget, I tried to change the name my icons exactly with the corresponding icons, same number of icons that are shown the same weather condition, I put them back in my widget but the weather shows me wrong AGAIN... WHY this happens??? What I'm doing wrong..??? :?
 Post subject: Re: icons and weather
PostPosted: March 5th, 2013, 6:35 am
There is the AccuweatherCore weather icon number description:
1--Sunny
2--Mostly Sunny
3--Partly Sunny
4--Intermittent Clouds
5--Hazy Sunshine
6--Mostly Cloudy
7--Cloudy
8--Dreary
9--null
10--null
11--fog
12--showers
13--Mostly Cloudy with Showers
14--Partly Sunny with Showers
15--Thunderstorms
16--Mostly Cloudy with Thunder Showers
17--Partly Sunnty with Thunder Showers
18--Rain
19--Flurries
20--Mostly Cloudy with Flurries
21--Partly Sunny with Flurries
22--Snow
23--Mostly Cloudy with Snow
24--Ice
25--Sleet
26--Freezing Rain
27--null
28--null
29--Rain and Snow Mixed
30--Hot
31--Cold
32--Windy
33--Night Clear
34--Night Mostly Clear
35--Night Partly Cloudy
36--Night Intermittent Clouds
37--Night Hazy
38--Night Mostly Cloudy
39--Night Partly Cloudy with Showers
40--Night Mostly Cloudy with Showers
41--Night Partly Cloudy with Thunder Showers
42--Night Mostly Cloudy with Thunder Showers
43--Night Mostly Cloudy with Flurries
44--Night Mostly Cloudy with Flurries
PostPosted: March 5th, 2013, 6:38 am
Thank you VERY MUCH for the clarification!
PostPosted: March 9th, 2013, 7:21 am
I also a related problem.
binding the %weatherIconNum2 (and others too form 1-7) doesn't work.
Here's what i've
an image control.
BindingCore : accweathercore1
CoreFormat : Icons/%%weatherIconNum2.png
I've all weather icons (1-44) in a folder 'Icons' in widget root directory.
Plz Help :?
PostPosted: May 1st, 2013, 2:45 pm
You have to change the code a bit. If you make even a single "error" using another symbol or number the code will not work!
Create a folder IN the (same) widget's folder using any name and the code like this:
(if your folder's name is "icons")
current weather
day1 weather
day2 weather
etc
PostPosted: May 1st, 2013, 4:38 pm
Thanks
The issue was with icon numbering which had I messed up. And the widget is already up at dA.
