XWidgetSoft Forum • View topic - HOTSPOTS Part1: Dock Style
It is currently June 4th, 2024, 4:45 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: December 1st, 2014, 12:01 pm
Tutorial using the "Jaku Dock" widget:
viewtopic.php?f=20&t=3910
TO CREATE/EDIT A WIDGET FOR ANDROID YOU NEED TO PRESS THE "Android Mode" BUTTON OF THE DESIGNER FIRST.
1. Create the basic design.
2. Add the Image components (the number depends on how many shortcuts you want to create).
For the WrapMode select Image Stretch to keep the same size for all the icons. Import your image/icon you want to use.
The Width and Height must be the same to keep the square form of the icon.
3. Add the ShortCutCore core (the number is according the number of the images you created)
4. Assign the Binding Core -> Shortcutcore for each image and select ${icon} for tag.
Image1: Shortcutcore1 -> ${icon}
Image2: Shortcutcore2 -> ${icon}
etc
5. Click on each ShortCutCore 1,2 etc and import the corrisponding/same image. Do the same for all the shortcut cores
6. Add the Hotspots:
Double click to add it (the number is according the number of the shortcuts you created).
The Hotspot is actually the area where you will touch on your phone's screen to open the shortcut. So be sure to resize it properly.
Should have the same size of the icon/image or a bit larger.
Assign the Binding Core for each Hotspot and select the !openFile tag for the Event->OnClick function.
7. Create the Right click options menu so you can edit the shortcut/app for each icon on your phone.
Add a MenuItem, edit its Caption writing for example Change Shortcut 1 and assign the corrisponding Binding Core and !ShowSetting as tag for the OnClick Event.
Repeat the same for the rest MenuItems/right click options.
Use this procedure to install the widget to your phone:
viewtopic.php?f=23&t=3776
Exit the Designer and Save.
Users browsing this forum: No registered users and 37 guests
