It is currently June 12th, 2025, 2:35 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: December 1st, 2014, 10:48 am
GENERAL
Each widget has the corrisponding "Right click"/Widget Options menu.
After add a widget on your homescreen touch on to open the menu.
1. GENERAL OPTIONS
This widget for example has 6 options available for DateTime and Weather.
2. STANDARD OPTIONS
* Select Widget
You can change the widget directly from your homescreen.
* Edit Widget
Opens the XWDesigner where you can modify ANY component of the widget.
Go back to exit.
* Settings And About
You can edit the various options like Scale, Rotate, Opacity, Align, Click Event, About.
CLICK EVENT
* Open an App
Use this option to assign any app when you press (anywhere) on the widget.
THE AVAILABLE HOTSPOTS OF THE WIDGET WILL REMAIN FUNCTIONAL.
Select it and the list of all your installed/stock apps of the phone will open.
Choose the app or go back to Exit.
This is a little different from the Hotspot function.
To check how the Hotspot works check the other topics in the main Tutorials section.
viewforum.php?f=23
Image Image
* Open Widget Menu
The Widget Options menu will appear after touch on the widget.
* None
WEATHER SETTINGS - MENU
The available Weather Options for the Weather widgets are:
* Update Weather
Use it to force update the weather. When the wifi is switched on, the weather will be updated automatically.
* Weather Information
Opens the Weather Details screen by Accuweather.com with the current and 15-Day-Forecast.
1. Option to change your location. You can find your location MANUALLY (wifi-network is required) or AUTOMATICALLY (using the Autolocation-GPS function. Check if ALL the necessary phone's options are activated) or enable the Always auto location (re-location every time update weather)
Select Autolocation or Clear History from your selected cities.
Image Image
2. Opens the Weather options menu.
* Updated Weather
Force update the weather.
* Change Location
Change your location. More info in this topic.
* Metric/Imperial units
Switch between Metrics (temperature in Celsius, wind in Km/h etc) and Imperial units (temperature in Fahrenheit, wind in mph etc)
* Update Interval
Select the time during the automatic update of the weather. (default value is every 1 hour)
* Weather languages
Select the language for the Weather Information screen (the language of the weather conditions ON the widget will stay in English. To use the phone's language you need to edit the corrisponding tag through the XWDesigner)
Available languages:
Arabic
Bulgarian
Catalan
Croatian
Czech
Chinese-Simplified
Chinese-Traditional
Danish
Dutch
English
Estonian
Filipino
Finnish
French
German
Greek
Hebrew
Hindi
Hungarian
Indonesian
Italian
Japanese
Kazakh
Korean
Latvian
Lithuanian
Macedonian (Fyrom)
Malaysian
Norwegian
Polish
Portuguese
Portuguese (Brazil)
Romanian
Russian
Serbian
Slovak
Slovenian
Spanish
Swedish
Thai
Turkish
Ukrainian
Vietnamese
