It is currently April 17th, 2024, 8:05 pm
PostPosted: December 23rd, 2017, 6:07 pm
To make a long story short, I just purchased a screaming computer and did a new install with W7. While doing this I tried to install 2 W7 on the same drive. Well, the other OP is still there but the partition has been deactivated so that I can't log into it anymore as it won't boot to that partition. I failed to backup all my widgets in Xwidget and some of them were custom and would take me a good bit of time to actually put them back to where I had them. I can still access that partition from my new install.
Does anyone know where Xwidget stores the widgets? Is there a way to copy that file and paste it into the new install?
Thanks again. ;)
Ok, I finally figured it out. I was able to repair the old partition so I could access Xwidget and from there I simply edited and published my widgets that I had customized and saved them on a flash drive.
So all is good. Thank you. :mrgreen:
