It is currently June 12th, 2025, 10:37 am
PostPosted: October 14th, 2016, 4:45 pm
:geek:
DOWNLOAD BELOW
PostPosted: October 14th, 2016, 11:59 pm
Great work! Thanks :)
I will post it in the gallery as soon as possible.
Keep more Android widgets coming.....
Edit:
Checked and unfortnately your widget has a lot of errors and missing parts. :!:
I will try to fix it by myself. I have to create it from the scratch...
PostPosted: October 16th, 2016, 4:14 am
FIXED VERSION for PC:
viewtopic.php?f=11&t=6463
You can download the Android version from the app's gallery.
PostPosted: October 19th, 2016, 3:46 pm
Missing second rotator if I download from android galery.
PostPosted: October 19th, 2016, 4:20 pm
I know. If you notice we have no clocks with seconds in the android gallery.
The seconds are supported but:
1) Tony, the developer, needs to check the seconds rotator movement because appears abnormal if you use it
and
2) We want to keep the app with lowest ram-battery usage. Using the seconds, will increase them.
So the second rotator was removed intentionally.
