It is currently June 12th, 2025, 11:09 pm
PostPosted: February 11th, 2014, 2:54 pm
XWidget v2.0 is developing
---- Support GPU hardware acceleration ,reduces CPU usage, more smooth animation ;
---- Suppoert 3D layer with smooth animation.
---- New UI, more easy to use;
---- New scripting engine ,lighter and faster ;
---- New widget editor ;
---- New Open Architecture: All cores will write by JavaScript Code and open sourse,everyone can create/modify core's source code.
---- Support embed one widget into another widgets as an component
---- More stability and faster
In total there will be more than 90 % of the code rewritten to improve the stability of the underlying
We are looking forward to comments and suggestions : viewforum.php?f=3
