It is currently June 12th, 2025, 12:54 am
PostPosted: October 29th, 2013, 8:06 pm
XWidget beta patch
How to uses:
1. Make sure you had installed XWidget and Exit XWidget.
2. Download patch
3. Unzip patch to XWidget's Install path and over write all files
3. Run XWidget
[Download]
download from here: http://xwidget.com/download_patch.php
[Update Log]
2013-11-11
Fixed: old WidgetPackage/ThemePackage Ext can not support problom
Fixed: Some weather tags not support problom
Fixed: XWDesigner Android mode hotspots can not display preview color problom
Add: XWDesigner Android mode support Rotatoer/NumbImg Controls,Battery Core
Add: AccuWeatherCore tags add "simpleWeatherIcon",only need 8 kind of icon: sun,cloudy,fog,rain,lightning,snow,moon,moon_cloudy
2013-10-30
Fixed old WidgetPackage Ext problom
Users browsing this forum: No registered users and 3 guests
