[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
XWidgetSoft Forum • View topic - Register Post and Download widgets on XWidget Chinese forum
It is currently April 24th, 2024, 10:47 pm
PostPosted: November 2nd, 2012, 8:37 am
PostPosted: November 5th, 2012, 9:45 pm
PostPosted: November 5th, 2012, 9:55 pm
Download widgets
to be continued...
PostPosted: November 28th, 2013, 11:19 am
THIS IS THE TUTORIAL FOR POST YOUR WIDGET IN THE CHINESE FORUM:
1) All the widget must be posted in "皮肤提交和发布 (Skin Release)" section. Then the Mods there will check it and it will be moved in "资源库 (Skin Gallery)"
2) On this page:
http://bbs.ku-yu.com/forum.php?mod=forumdisplay&fid=37
click on the button:
3) Then select the 2nd option on the left and add the title/name of the widget:
4) Now you need to upload image and file (.xwp)
IMAGE:
Press the buttons with this order:
and click on the image's link that is created inside this window.
FILE:
Same opearation for upload the .xwp file. (max file 16Mb)
The Mods want clean files not zip or rar.
The image and the file/s will added in post the position where you click on.
Add your text (I use Google translator for the chinese). We know that sometimes the translation is bad but the people there don't understand the english language, so your text must be in chinese!
At the end press the dark button on the bottom to create the topic:
If you want to edit a topic press the "pencil" button on the end of the post..
NOTE: If you have more than one file the upload function supports multi-selection.
