XWidgetSoft Forum • View topic - widget from PC on Android
It is currently April 26th, 2024, 7:18 pm
PostPosted: December 29th, 2017, 8:09 pm
How can I use my widget from PC on Android if it works through script.js? Is it possible? Or some alternatives for script.js?
PostPosted: December 30th, 2017, 1:35 am
Topic moved in the right section.
Please read this tutorial:
viewtopic.php?f=23&t=3776
Java script is not supported for the Android app.
There are some functions though that work in alternative way on the phone, like multibackground selection, day night background image.
For now these cores are supported on Android:
Datetime, Weather, CPU, RAM, Battery, Photoalbum
You can check the cores and the components supported by press 'Android Mode' in the XDesigner.
Users browsing this forum: No registered users and 327 guests
