It is currently October 23rd, 2026, 10:06 am
 Post subject: Touch Me!
PostPosted: March 5th, 2016, 5:16 am
Something funny, crazy, spooky...? It's up to you to decide ;)
Put the widget on your desktop and let the others discover it..
* MOUSE ENTER/LEAVE the widget....
* The widget starts with no sound.
Right click to select which sound will play or not.. (3 available sounds or mute)
NOTE: The pngs are created by me using the original gif file that I found searching on Google images
(posted by RevJamesSway-2 years ago on imgur.com)
Special thanks to @meme who helped me with the scipt/playing sounds.
Ejoy! :)
touch_me!.xwp [3.95 MiB]
Downloaded 419 times
Users browsing this forum: Bing [Bot], Google [Bot] and 159 guests
