This is a reformatted version of the
Galaxy S6 Lite or "Simple" developed by XDA member Aatif Bilal and found here:
http://forum.xda-developers.com/android/apps-games/xwidget-samsung-galaxy-s6-weather-t3045314. It uses pretty much the same fonts, except for the clock, for which a text object was used to incorporate my preference of the hour having no leading zero. Thus the shadowing that comes with the original is not here, but you can replace it with the S6 images used in the original if you want. Also, the objects are aligned left and right to make a nice, simple 4x1 widget. It also has:
- 5% shading for viewing with lighter wallpaper.
- Hotspot at refresh date/time to refresh weather.
- Hotspot on current temperature to go to weather details.
- Hotspot on city to change location.
Enjoy.
galaxy_s6a.xwp [2.42 MiB]
Downloaded 370 times
