It is currently June 12th, 2025, 12:14 am
PostPosted: September 14th, 2014, 9:20 am
Special thanks to hamid for his help with the script.
Original design by Provocator.
A high quality customizable analog Clock/Weather widget.
* Time/Date
* Celcius Analog Meter
* Fahrenheit Analog Meter
* Battery Metter
* Extra Slidepanels: Calendar / Forecast
* 4 Different Backgrounds/Styles
RIGHT CLICK OPTIONS:
- Clock Mode
- Temperature Celcius Mode
- Fahrenheit Celcius Mode
- Turn ON/OFF Blink
- Clock Face ON/OFF
- Black Metal ON/OFF
- Date Info ON/OFF
- Grill
- Metal
- Wood 1
- Wood 2
CLICK ON OPTIONS:
- Click on "Calendar" left button/icon to slide in/out the "Calendar Panel"
- Click on "Weather" right button/icon to slide in/out the "3-Day-Forecast Panel"
EDITED: 16/9/2014 (by @hamid)
1. Added: Saveini and menuitem checking for menuitems
2. fixed: location changing by removing one of the accuweathercores and changed the code to work only with one
3. fixed: celcius/fahrenheit changing by changing the textonchange function in the code
4. fixed: slidepanels to not get in the behind of another; now when you slide one, other one will slide-back
5. changed: position of [time] and [date] objects to [timee] object in the widget tree;
to be compatible with changing clock mode and saveini; (also adjusted the position of them in new place)
old_school_dashboard.xwp [6.33 MiB]
Downloaded 228 times
PostPosted: September 14th, 2014, 10:23 am
Very nice!
PostPosted: September 14th, 2014, 11:25 am
Slavoo wrote:
Very nice!
Thanks Slavoo! :)
PostPosted: September 16th, 2014, 5:12 am
Please download the latest version....
Users browsing this forum: No registered users and 7 guests
