It is currently October 23rd, 2026, 8:13 am
PostPosted: July 24th, 2014, 4:22 pm
A full screen weather widget with detailed weather informations.
*** ONE THE FIRST RUN, move and fit the widget on the screen and then PRESS "ESC" to hide it. ***
* A small icon will be placed on the bottom-right of the screen.
* Click on the icon to show the full screen panel / press "ESC" to hide it.
The main background/blur image will change according the weather conditions.
- Change Location (or click on the city's name)
*** FITS ON 1366x768 SCREEN ***
EDITED: 25/7/14
Added extra right click option to hide the panel not using only the ESC key
weather_pro_full_screen.xwp [6.83 MiB]
Downloaded 281 times
PostPosted: July 25th, 2014, 1:46 am
EDITED:
