It is currently June 12th, 2025, 4:44 am
 Post subject: Clear Player (animated)
PostPosted: July 18th, 2014, 4:07 am
\\\All credits to hamid who realized my idea writing the great script code.///
***Based on the design by twaintyfour.***
A unique Music Player widget will full animation, special modes and mouse over options.
- Close Player
- Select Disc Type (normal, mini and none) = Useful for control the CPU usage
- On Widget Closed (select if the WMP will open after close the widget)
Default: Do Nothing
- Enable Large Cover (on/off) (DiscBoxCover)
- Enable Disc Rotation (on/offf, less cpu usage)
- Enable ArmMove While Playing
Use the buttons for:
- Add song
- Edit Tags
- Search Cover Tool
- Shuffle
- Repeat
- Player Settings
* Click on the Volume Meter and use the mouse wheel to control the Player's Volume.
* Click on the next button to Mute On/Off
* Mouse over the small DiscBoxCover to View/Hide the full Cover.
22/7/14:
Added default right click option "Do Nothing" after close the widget.
clean_player.xwp [686.38 KiB]
Downloaded 184 times
PostPosted: July 22nd, 2014, 12:51 am
Users browsing this forum: Google [Bot] and 41 guests
