It is currently June 12th, 2025, 12:57 am
 Post subject: Broken Screen
PostPosted: May 8th, 2014, 2:15 am
A big thanks to qiancang and hamid for their precious help and time creating the script code.
A unique and funny "widget"! Click everywhere on your desktop and will broke your screen!! :D
* 12 high quality broken glass/cracked screen images that they will appear IN RANDOM ORDER.
* 5 cracked glass effect SOUNDS with RANDOM PLAYBACK.
* 2 MODES:
- One Glass: Will appear only one broken glass image on your screen. (the previous image will disappear)
- Multiple Glass: The broken image will stay on screen having the possibility to add numerous images on screen.
* The desktop will be full operational since the widget use the "through widget" function, works and its right click menu will appear only when the ctrl key is pressed.
**** HOW IT WORKS****
- HOLD DOWN the CTRL button
- DOUBLE CLICK everywhere on your desktop
**** RIGHT CLICK OPTIONS / MENU****
(This will appear ONLY when the ctrl key is pressed)
- Select mode: One Glass / Multiple Glass
- Clear Glass: You can clear the current broken glass images from your desktop and the widget will still run in the background.
- Turn ON/OFF the crack sounds
- Select "Close" to completely close the widget.
broken_screen.xwp [1.71 MiB]
Downloaded 201 times
Users browsing this forum: Bing [Bot] and 9 guests
