It is currently June 12th, 2025, 1:13 am
PostPosted: April 22nd, 2014, 3:25 am
Special thanks to digigamer who helped me with the animation's script/right click options.
A simple minimalism style digital clock widget, but not so simple as it seems... :D
* MULTI-COLOR : RGB panel to select the color/transparency.
* MULTI-ANIMATED: Animation for HOURS, MINUTES AND SECONDS.
Maybe the first widget for XWidget that gives the possibility to select one of the 24 IN TOTAL SWITCH EFFECTS available in the XWDesigner.
- Select Animation (ScrollBottom is the default one)
- Change color / transparency of the text.
EDITED:
Added a missing part of the script to fix the right click selection bug.
PLEASE DOWNLOAD AGAIN
minimal_multi-animated_clock.xwp [166.01 KiB]
Downloaded 205 times
PostPosted: April 23rd, 2014, 4:27 am
EDITED:
Users browsing this forum: No registered users and 7 guests
