It is currently October 23rd, 2026, 3:18 am
 Post subject: Safe Shortcut Widget
PostPosted: February 4th, 2014, 9:05 am
Special thanks to Hamid for his awesome work on the script code.
A unique widget for your desktop! 8-)
* Click on the safe to show/hide the panel and put the 4 DIGITS PASSWORD.
--THE DEFAULT CODE IS 1234--
- Shortcut settings (support for drag-drop function, use can put a single file or folder)
- Change the password (confirm the old code-write the new one)
- Re-Lock/Close the safe
NOTE:
* The widget provides a security function, but the code is not unbreakable. So it will NOT provide a true security for your files.
Only who will install this on his/her computer will know the "trick"
* To reset the password close the widget.
safe_shortcut_widget.xwp [325.87 KiB]
Downloaded 272 times
 Post subject: Re: Safe Shortcut Widget
PostPosted: February 4th, 2014, 12:05 pm
Nice job guys.... :D
PostPosted: February 4th, 2014, 12:23 pm
Thanks meme! ;)
Users browsing this forum: Google [Bot] and 148 guests
