It is currently June 12th, 2025, 3:20 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: November 11th, 2013, 9:15 pm
Thing to note as possible When you create widgets for Android
[Please make sure your had update to the lastest version of XWidget for Windows Patch viewtopic.php?f=2&t=3715 ]
1. Please Add menuItems when you uses core (etc: DateTimeCore,WeatherCore). And please as possible to drop down list to select menuitem which will auto translate.
Please Add "12/24 Hour clock" and "Time Zone Settings" menuItems when you create widgets with DateTimeCore
Please Add "Weather Information" and "Time Zone Settings" menuItems when you create widgets with WeatherCore
These menuitem will be Auto Translated
2. Auto make a default image for widget with no date loaded. If you do not want some control display in default image,just uncheck the property:
3. Auto make a new widget icon with new size 256
4. In order to better compatible with XWidgt for Android ,Please try to Set Vert-Align to "Top" as possible , not set Vert-Align to "Middle" as possible .
PostPosted: November 25th, 2013, 11:22 pm
Addendum tip: You can use the default image itself as the background in your widgets to save space!
Users browsing this forum: No registered users and 6 guests
