It is currently June 14th, 2025, 7:18 am
PostPosted: September 18th, 2013, 9:09 pm
win8 style volume.
press left and right mouse button to adjust system volume at anytime,anywhere.
release right mouse button to hide widget.
please upgrade your xwidget to 1.8.4.716
XWidget_patch_1.8.4.716.rar [5.97 MiB]
Downloaded 302 times
mouse_gesture_win8_volume.xwidgetpkg [3.78 KiB]
Downloaded 325 times
PostPosted: September 19th, 2013, 3:00 am
It would be great!!! but, doesnt works for my...
I have Windows 7 x64
Should I to modify some settings of mouse or windows?
PostPosted: September 19th, 2013, 5:34 am
no need to modify anything.
xwidget version 1.842 or newer required.
this widget is invisible unless you press left and right mouse buttons at the same time.
keep left and right mouse buttons pressed while you slide mouse to adjust volume.
PostPosted: September 19th, 2013, 10:26 am
I have 1.8.4.610, but doesnt works for my...
so sad :( because the idea is genial!!
I have an HP 2.4 Ghz wireless laser mobile mouse
HP product number wx406AA
I also try with another mouse, and doesnt work...
PostPosted: September 19th, 2013, 11:06 am
Sorry to say, but it is also the same with me, too. Unfortunately it doesn't work. (Win7x64)
The widget doesn't appear when I'm pressing both mouse buttons together and move the mouse.
PostPosted: September 19th, 2013, 5:19 pm
1.8.4.610 is too low. i'll upload the 1.8.4.716 patch tonight.
PostPosted: September 19th, 2013, 5:22 pm
Doesn't work for me too :( widget doesn't appear on dual mouse click.
PostPosted: September 20th, 2013, 3:48 am
i have uploaded the new patch
PostPosted: September 20th, 2013, 5:33 am
I couldn't install the patch because my anti-virus program deleted it instantly (xwtest.exe and xwdesigner.exe) :?
PostPosted: September 20th, 2013, 2:19 pm
Great! now works but... xwidget become chinesse characters!!
But I replace the default "lang" to english :)
PostPosted: September 20th, 2013, 2:52 pm
XWidget is 100% safe. Just a false alarm!
PostPosted: September 20th, 2013, 5:14 pm
It's not that I disagree, but how do you know it is 100% safe ?
Does the new patch give Xwidget the potential for key stroke logging and it already has internet access. :?: Dangerous potential :!:
PostPosted: September 20th, 2013, 5:37 pm
I know what do you mean meme... Personally I never had problems with the XWidget and alarms of my antivirus, normal or patched versions.
Users browsing this forum: No registered users and 38 guests
