It is currently October 23rd, 2026, 10:15 am
PostPosted: June 10th, 2013, 7:44 pm
Special thanks to Cov for the idea and his help with the suggestions! :)
Includes 5 Gauge Widgets:
CPU
RAM
HDD
SWAP
BATTERY
On HDD widget right click for select the drive.
To add multiple HD widgets:
Then right click on the 2nd, 3rd.... widget a click select drive.
EDITED: I inverted the colours in the Battery widget to match with the actually level.
Please DOWNLOAD AGAIN!
cute_mini_gauges_pack.zip [1.2 MiB]
Downloaded 253 times
PostPosted: June 11th, 2013, 5:26 am
