It is currently June 12th, 2025, 12:03 am
PostPosted: October 23rd, 2013, 7:03 am
Attributes
.font.fill.color
text,edit and memo component font color.
text1.font.fill.color = rgba(0,0,0,255)  //black
edit1.font.fill.color = rgba(0,0,0,255)  //black
memo1.font.fill.color = rgba(0,0,0,255)  //black
.text.font.fill.color
button and badge component text font color.
button1.text.font.fill.color = rgba(0,0,0,255)  //black
badge1.text.font.fill.color = rgba(255,128,128,255)  //pink
.background.solidColor.color
all components background solid color.
image1.background.solidColor.color = rgba(0,255,0,255)  //green
layer1.background.solidColor.color = rgba(150,150,150,255)  //grey
text1.background.solidColor.color = rgba(0,0,255,200)  //blue
Functions
rgba(red,green,blue,alpha)
set color as rgb format.
red,green,blue: integer,0~255. example: black=0,0,0 white=255,255,255 red=255,0,0
alpha:transparency, integer, 0~255.
SelectColor(defaultColor)
select color via colorboard.
defaultColor:colorboard will return defaultColor if you click cancel button.
text1.font.fill.color = selectColor(text1.font.fill.color);
image1.backgroud.solidcolor.color = selectColor( rgba(255,2,2,255) );
getScreenRGB(x,y)
get the color of screen point(x,y).
x,y:screen point.
this function will return string in 255,4,29 form. it doesn't contain the alpha information.
var rgb_str = getscreenRGB(100,34);
var color_str = rgb_str+ "," + 240; // add alpha to the string
var color = eval(  "rgba(" + color_str + ")"   );
text1.fill.font.color  = color;
to be continued
