It is currently June 12th, 2025, 11:32 pm
PostPosted: October 3rd, 2013, 4:36 am
Took me a while to translate all those stuff. (Yes, I used Google Translate. Chinese is completely alien to me... But I'm good in English ;) )
http://goo.gl/ZvFfFk
Take the file, unzip it and put it in the ${XWidget_Install_Path}\Res\Strings folder. Now all your auto-complete text will be in english. Where ${XWidget_Install_Path} refers to the folder you've installed XWidget in. Most probably it will be the "Program Files" folder.
**The original file had some format issues. Gave a hard time to guess the appropriate encoding format, decode it and translate it. Translating 4000+ lines is massive indeed! :mrgreen:
This is for the version 1.8.4.610. Stay subscribed for future updates. Also please let me know about any errors that might have crept in. Though I have thoroughly organized everything, errors are bound to creep inside!
Planning to prepare a PDF about these. It will then serve as the complete guide. Will post as soon as complete. Hopefully within a few weeks.
**To the devs: I'm willing to volunteer for all these translating stuff, if you please.
PostPosted: October 3rd, 2013, 5:25 am
Wow! Thank you very much!!! This is extremely helpful! :D
PostPosted: October 3rd, 2013, 10:33 pm
Thank you digigamer, awesome job :P :D
PostPosted: October 17th, 2013, 5:16 am
There is some documentation missing about downloadfile and downloadstring and possibly many others. If you know something... Help the community and add it here
PostPosted: October 20th, 2013, 5:39 am
Great job! Thank you very much, I will add this file into xwidget's english version :)
PostPosted: October 21st, 2013, 3:53 am
Happy to help :D
PostPosted: October 14th, 2014, 1:00 am
Am I assuming incorrectly that this download has now been bundled into the latest download version? or does this still have to be done by each and every newbie?
PostPosted: October 17th, 2014, 11:17 pm
i don't think too many things added or changed from that version till now,
just it has some sorting and spelling problems
i have created a modified version of it for myself,
i have fixed some of them that i mostly use,
also i have added some other things that doesn't listed in the file,
maybe i will upload it here later,
(or maybe it's not necessary, since ver2 is coming)
Users browsing this forum: No registered users and 4 guests
